IN (delta system) how RMU earth fault indicator operates , and what is the function of the used medium voltage cable toroid (only one toroid allaround the 3core cable), does it only measures the surrounding or the sum of magnetic field of the 3 ph or what it actually sensing? and in another types of EFI it uses 3 toroids for each ph and in another types which used foe EFI+SC it uses the combination 3toroids +allover toroid, what is the difference?
and for medium voltage cable does the earth fault indicator with CBCT operate with ph to ph faults and unbalance conditions such as open conductor (like only one fuse is open so there is only 2 ph operating so there will be unbalance)?
what is the difference between earth leakage relay and earth fault relay and earth fault indicator?thanks
