earth leakage relay vs insulation monitoring device 2
Ali-rashid
19
Hi All
Can we use an earth leakage relay instead of an insulation monitoring device? Do they provide the same protection?
Dear Mr Ali-rashid
Q. Can we use an earth leakage relay instead of an insulation monitoring device? Do they provide
A. An earth leakage relay is used to detect earth-leakage (fault) in a system where the [source
neutral is earthed]. A [trip signal] is issued when the earth-leakage fault current exceeds the
current set value (usually not exceeding 5A) and the time delay (usually not exceeding 0.5s).
An insulation monitoring device is used in an isolated neutral [neutral is isolated from earth
or system without a neutral] systems. An insulation monitoring device usually indicated the system
[insulation resistance] in Mohm. When the insulation resistance is lower than the set Mohm value
(usually not lower than 1 Mohm in LV systems), the device closes a N.O. contact to [activate the
(external) alarm]. Low insulation (fault) usually does not required {an immediate tripping}, but
must be attended to ASAP.
Note: In an isolated neutral system, the [first line] shorted to the earth does not cause any over-current and the system operates normally, but must be attended to (urgently !) in order to prevent the [second line] shorted to the earth; which will result to a line-to-line short.
Che Kuan Yau (Singapore)
Thanks Che. Your comment along with some search got me the answer.
