Ariel15
- Feb 20, 2024
- 2
Hello colleagues, I am designing an earthing grid for a 50 MVA power generation plant with 8 generators and two 25 kVA 34.5/13.8 kV Y-Y transformers with the neutral grounded on both sides, single-phase short circuit of 7 kA, and I have the following doubts if anyone would be so kind to help me. Thank you in advance.
1- I understand that in a Y-Y installation with the neutral grounded on both sides, in the event of a ground fault, the current would return through the neutral and not towards the earthing grid, so I wouldn't worry about GPR or dangerous step and touch voltages. If this is the case, how should I proceed, and what requirements should the designed grid fulfill?
2- How do I know if it is necessary to ground the fence, i.e., at what distance from the grid can the fence be without it being dangerous not to connect it? In the installation, it could be 8 m away from the grid.
3- Any other special considerations I should take into account for the design based on your experiences.
