Earthquake response - Single degree of freedom elevated mass
Dunc26
6
Hello
Don't know if this is in the right forum but I'm looking for some tips on analysis of the earthquake reponse of an elevated mass. I have the mass, the natural frequency and the damping coefficient. I am also told the ground acceleration due to the earthquake can be approximated by the constant spectrum So=0.0075m2/s3.
I am struggling as to how to use this in an attempt to find the frequency response function of the mass and the mean square response of displacement.
Any pointers??
Hmmmm I think earthquake response are typically in PSD or g^2/hz, which in turn is Random Vibration. I'm not sure what the So=m2/s3 is...
Tobalcane
"If you avoid failure, you also avoid success."
Thanks guys
How do I go about using the response to find the response function of an object?
You work out the trandfer function for a single degree of freedom system and multiply it by your excitation spectrum.
Cheers
Greg Locock
Perhaps it's time to re-read the course text, or find a different one that may be more comprehensible.
Mike Halloran
Pembroke Pines, FL, USA
Ohhhh...thanks IR
Tobalcane
