Just wanted to get some input as to the methods others use to estimate volumes of dirt from utility trenches. I am only interested in pipe spoils really, what is remaining after excavation and backfill.
I am an Agtek User and find it I can't get a final volume using earthwork 3D. I can calc the whole trench volume, but it takes a lot of work. Materials 3D will probably do the job if proper set up is done. But you can't apply swell factors or map the strata in that program. I am not currently using that program to the best of it's aility.
What methods do you use to determine pipe spoils on a project when dealing with over all site balance? Is there an easier way than determining linear footage by hand calc's and applying the trench cross sectional area?
If you're an Agtek user, how are you using earthwork 3D to determine final trench spoils?
Any input would be great.
