kevshug65
Industrial
- May 19, 2008
- 4
I'm on 2007sp3.1 and just recently a problem is showing up while dimensioning drawings. When the mouse moves over an edge of a part, the edge used to highlight before selecting it, now it does not and the precision is gone while trying to blindly select the edge with mouse clicks. It is somewhat easier to select the first edge, but second edge selection is very difficult. We design wire type displays, such as wire grids, shelving etc.. The drawing view is set usually to projected, but same thing happens in true mode. My current PC has been working great for over a year, no problems. Although the graphics card is not certified (geforce 8500GT) I haven't had any problems until the past week.
Since the problem started, I've played around with quality settings in system/document properties and cosmetic thread draft/high quality, also tried different display styles (shaded,wireframe,etc.) But no luck so far. Any suggestions appreciated.
