Edit/Find...
kdeni
Automotive
May 9, 2018
5
Hi All,
sometimes I have to check drawings. I have to search texts on main sheet. I use the Edit/Find... command, but it doesn't work, if the texts are in 2D Component. It is possible to find the texts "everywhere" on the main sheet ?
I think you will need to explode them first, just don't save file afterwards.
Use the search command
Choose search and select
then RMB on one of the selections
Not realy. I have lot of Texts, Tables, 2DComponents with words, numbers, sentences. I want just find and select a subtext, what I need.
