Im currently trying to automate a drawing. One problem that im facing is that I would want the tabular note to be able to automaticly change size (in this case number of rows) depending on the value of a cell in the table or by expression.
For example:
I have a table with 10 rows and 3 columns. Lets say that if any value in the third column is bigger or equal to 10, that complete row should be excluded in the tabular note.
I have tried using "Edit using spreadsheet" and I hoped that I could find some way to control the printing area but with no luck. It seems like the NX-integrated Excel print all cells that contain any kind of formula or value, even if the cells in a row are controlled to be blank.
Does anyone have a solution to this?
nx 2007.2011
For example:
nx 2007.2011
