deek05
- Jan 11, 2002
- 48
I posted this on a couple other user groups, so you might have already seen this.
Here's the deal (this may be long): We use Autocad and Solidworks (SW). Drawings printed from Autocad and SW are considered MASTER drawings. Drawings printed anywhere else on plant (using a drawing viewer) need a time/date stamp saying "This Drawing Valid For 7 Days After: 8/3/2004, 11:14am". This is part of our ISO 9000 standards.
We currently use a program called Fastlook+. It's a good program but occasionaly there are some compatibility issues with SW. We would like to use eDrawings to view both Autocad and SW but need the time/date stamp.
I was able to print a time/date stamp using Solidworks Viewer, but I have to type in the stamp info in the custom header/footer settings everytime I print. Is it possible to get this custom header/footer text to stick? If I could get it to stick then I could change the front end of our drawing viewer to find anything with a .DWG extension to use
Autocad and anything with a .SLDDRW to use Solidworks Viewer.
Note, I did add the info to the custom header/footer to the SW drawing template. The problem is that the drawing printed from SW can't have the time/date stamp on it (see above).
Any ideas?
Any ideas?
