- Thread starter
- #261
The video is completely misrepresenting the true situation.
Take his column A where we spend the money.
If spending the money creates global economic recession when it is false, it will cause the same global economic recession if it GCC is true.
Except. He talks about Global Climate Change man-made or not.
That's the danger of re-branding half way through.
We are back again at the runaway greenhouse or the new ice age.
So his real options are:
[ul][li]GCC Warming true[/li]
[li]GCC ice age true[/li]
[li] either or but nothing we can do[/li][/ul]
Now when we act we have two options, to combat warming or to combat cooling. There is no proof of either.
SO we have far more outcomes to consider and any mismatch combination is not only going to create global economic recession (unless we do nothing) it also has a 50/50 chance of making things a whole lot worse.
Now lets go to the d nothing column. Whatever the options we have to consider that doing nothing in each case is the safest option unless we know for damn sure what the true condition is because that smiley face has aabout one appearance in five.
SO in his row 2 column 2 where the doom and gloom catastrophe is outlined, that also applies to several of the options in column 1.
We can all draw smiley faces. But at 6 minutes 47 seconds in I'm thinking this guy is pitching it perfectly to all those who believers.
This presentation is a sort of shell game. He tells you your options but you really have to list your own options and check up on him.
You must in fairness to his logic consider the various options as I've outlined them above or you are cheating as he is.
If I say you can be rich and unhappy or poor and happy, we all know we have to choose to be poor and happy.
But, you shouldn't accept that those are the only two options just because I tell you so.
You can on your own initiative ad in rich and happy and poor and unhappy.
Once you do that you realise that the optimum outcome is diametrically opposite to the original. Now instead of choosing to be poor, to suffer all sorts of global economic catastrophe, you choose to be rich. That's because being rich and unhappy is better than poor and unhappy.
In our scenario it would be a real B***ger to wake up having spent all your money and committed yourself to a global economic depession only to discover you spent it on the wrong thing because now you need even more money to fix the previous fix and fix the real problem and you don't have money.
Better to wake up one morning and have money left to help you survive.
Of course, once they can really prove not only which scenario is true but the magnitude and the true benefit/deficit of that scenario then you can do something.
If there's no time left. Too bad. The no time left scenario s true of any outcome but doubly true of any wrong choice first time round precautionary principle.
The guy says he has run this by all his friends and no one can fault his logic? Yeah? then get new friends.
JMW
JMW
