effect of RH% and temperature to cement 1
leyron
15
i only want to know, what is the effect of temperature and RH% to the cement, so that we can make a suitable design for our cement warehouse?
How are you storing or handling you cement? How long will the cement be in the warehouse or starage container?
If the cement is in silos it would be dry, but it will probably be cycles often enough.
If the cement is pure Portland cement in bags, in most cases, the packaging should provide 30 days under normal atmospheric conditions if it is not subjected to exterior moisture (as in rain). Rarely, would there be a situation where cement would be stored that long. Bulk cement is usually bagged with a short delay to allow flexibility of use and the high cost of inventory.
Dick
we will construct a warehouse for the cement alone, and it is tightly sealed for the rain to enter and for direct sun light. in that condition how long could we store the cement? is there any maximum shelf life of a pure portland cement?
in addition during dry season we will open the door to let the fresh air to enter the warehouse with the help of the exhaust fan 1500 cu.m/min capacity to circulate inside the warehouse to remove the excess heat, but during rainy season we will shut down the door and the exhaust fan to avoid moisture to enter the warehouse.
We still need to know how the cement is stored. Silos? Bags? Open bins? Piles on the floor?
the cement are stored in bags and it is piled on a pallet.
It sounds like you are doing the right things in storing your cement. I don't know specific guidelines for temperature and RH in cement storage, but most cement companies will retest their products if storage time exceeds three months.
No effect on bagged cement since the bags are water proof. May be stored anywhere that has no impact causing leaks.
That depends on the bags. Some cement companies have warnings on the bags telling the purchaser that the bags are not waterproof.
Bagged cement can have a shorter shelf life than bulk because of the packaging, palletizing and pressure from the weight above (usually 3-4 pallets high as a maximum). Time also becomes a factor.
No matter what your created conditions are, you still have to have openings to get the cement in and out and provide proper ventilation
Cement companies do not try to store packaged products any length of time because of inefficiencies created and the long experience. It is usually preferred to store it in steel silos after grinding and sell it in bulk or packaged since packaging can be a short turn-around and keep the package inventory at a reasonable level. Cement bags can have hard corners due to the pressure due to the compression and and any possible moisture are compounded. - No matter what the cause, the ultimate user will complain because the product cannot be mixed/used properly.
The variable conditions, lack of an average storage time and normal packaging problems make an accurate answer unrealistic.
