JeanMicheling
- Oct 5, 2005
- 91
I think I have a good question for all the people in bearing design applications. I have two different opinions from experience bearing guys. If I add a spacer between two angular contact bearings, both agreed on the fact that it will increase the system rigidity. But one says that it will lower the load on each bearing, thus increase the bearing life, because the load is better distributed. The other one says that it's the opposite, because the system becomes more rigid, the bearings carry more moment load, thus shorten the bearing life. I find that really interesting and I'd like to know if someone has an answer or an idea.
