BAGW
- Jul 15, 2015
- 388
Hi All,
I am designing cross bracing consisting of stocky tubes say 10x10. They have been analyzed as compression and tension braces. When they are subjected to lateral loads, one brace will be in tension and the other in compression. In such scenario, it can be assumed that the tension member braces the compression member in and out-of plane direction. That is for the compression member half the unbraced length can be used to calculate the compression capacity.
Lets consider a scenario where both braces are in compression (one brace experiencing high compressive force and the other one a smaller force), say under gravity loads. Both the braces have similar length and similar cross sectional properties. In this case, I was in the impression that the braces need to be designed based on full length of the member. But, I was told that, even when both the members are in compression, it can be assumed that they brace each other in in-plane and out-of plane directions. This is because, when the brace with higher compressive load starts to buckle, the one with the smaller force goes into tension. Is it correct to assume the half the unbarced length for the design in such circumstances?
