Effective Seismic Weight? 1
SteelPE
2,759
Believe it or not I am having another disagreement with someone in my office on how to calculate the effective seismic weight of a building. This disagreement involves what to do with the walls that run parallel to the assumed direction of the seismic load. I have always included the weight of these walls when calculating the base shear on the structure. The only time I don’t include them in the seismic weight of the building is when the wall is a structural element (for example CMU).
The reference project is a steel framed building with a brick façade. I included the weight of the entire perimeter (because I don’t want to drive lateral loads through a veneer) while he is saying I don’t need to include the walls that run parallel to the seismic load. Applicable code is IBC09.
How do others handle this situation?
Hello
The mass should be taken entirely for seismic load
As for wind versus seismic it depends the type of structure and since we have important load located in a significant height the seismic could be governing....
saad73joss -> True.
I saw a increase in seismic force only due to the green roofing that is now quite popular !
I would add that sometime, wind govern on a certain height and the seismic can govern on another !
