When designing a balloon framed stud wall with a parapet what span lengths do you use for the effective wind area = (span length)*(span length/3)? For example, if you have a 15' tall wall with a 5' parapet and you are designing the stud, would you use one single effective wind area of (15')(15'/3) for the back span as well as the parapet or would you use a separate (5')(5'/3) for the wind portions on the parapet itself? When you start looking at the zone 2/3 negative GCp values for the rear side of the Windward parapet, it can make a pretty big difference in the end results of the design.
