I have a problem with flow measurument in two joining water lines that seems to be caused by an ejector effect at the connection. The main header is a 10 inch line with normal velocity of 1.75 m/s. I then have a 6 inch line connecting via a reducing T. After the connection the line velocity in the 10 inch header is 2.44 m/s. We hve tested the flowmeter and am sure that the instrument is fine. The line is not under vacuum but we have a suspicion that the 6 inch line might be - due to an "ejector effect" caused by the larger line and flow.
Does anyone have a similar experience with a piping arrangement like this in a seawater system?
