Ejector Manage together in Mould Tooling Design
Sendoacf
Chemical
Jun 10, 2022
8
Im working with the Mould Tooling Designer and I have a question
When I insert my Ejector pins or sleeves using the Catia V5 tool i can puth them together using sketch. After this i can split them all with in one operation using a plane or a surface. But now i want manage them together like if they were a single part, i would like to make them all a pocket for example. How could i do
Hi Sendoacf,
I'm also using Mold Tooling Design workbench! It has a few (many...) shortcomings, but I haven't found yet a faster way to put together the type of tooling I'm building.
About your question, what exactly do you want to do? Open the pockets for the ejectors?
That is very easy if you use the command "Distributed Drill Component", and you can do all the pockets at once.
If that's what you are looking for let me know and I can show you how to do it.
