jdogg05
- Jan 14, 2013
- 77
I understand for storage and preservation a lot of larger electric motors have bearing heaters to keep the bearings in a certain termperature range in cold climate conditions. What exactly is the rationale behind this? I understand why shafts need to be rotated to avoid brinneling, but why do the bearings need to be kept warm? I heard it has to do with the freeze/thaw/freeze cycle that happens in cold climates. But why does this matter? Does the lubricant degrade? Does moisture somehow get in from the outside?
