I have an application where I have four electric cylinders pressing down on the lid of a cart to press a laminate material together before the cart goes into an oven. There are many different carts so I cannot run the cylinders to a position, I am using the current pulled by the motor.
When the cycle is started the cylinders will extend until they touchoff on the lid of the cart. (which will never be level or in the same position). Then I will start running the cylinders very slow until each one senses that is bottomed out on the cart. My issue is that I want the four cylinders to bottom out on the cart at the same time.
My first thought is to use position to calculate velocity. that way if one cylinder is ahead of the others it will be running at a slower speed, therefore allowing the lagging cylinders to catch up. By the end of the stroke they should all be pretty close to the same position.
Does anyone else have any thoughts or suggestions? Any help is greatly appreciated.
