I have been requested to install a multiple tap autotransformer in the 3 phase line which is feeding a 51KW, 575V, 72.8 FLA water resevoir pump to reduce the 630V supply line to 600V or less. This 630V is believed to be what has been causing this pump motor to burn out on at least 3 occasions over the last few years. Could this high supply voltage be causing this motor to fail?
