Electric part design , cannot select multiple connections 1
Bogdan1985
72
Hi Friends,
I have CATIA R16, but works fine so fare. I tried to make a none electrical part to
a part with multi connections but can select single connections only. The part is
a body. I cannot select multi connections.
Knows anyone whats wrong?
Thx Bogdan
I did't understood the question, provide more details, maybe photo.
Once a CATPart Electrical Component is defined as a specific Electrical Datatype it is locked into that type (Single Insert Connector, Multi Insert connector, etc). To my knowledge, there is not a way to make a modification between connector types. The component will need to be recreated in a new CATPart file and defined as a Multi-Insert Connector from the start.
Those Connector types also dictates the type of connection points (Bundle, Shell, Backshell, etc) which may be added to 'Electrify' the connectors.
--Doug
