Most EV conversions use a 9" 20HP (15KW) series wound DC motor. I would like to have regenerative braking using a 20-35HP(15-26KW)3-phase electric motor(0~3,000 RPM)run by a VFD. Seimens makes AC motor/drive combinations for EVs, but the cost is a bit high for my liking ($6-10K).
Are there any other commercial VFDs on the market that run from a DC power rail of 200V or less and have dynamic braking using an external load resistor bank?
The motor I would prefer to use would be a sealed, fan-cooled unit with dual out-put shafts.
What I would like to be able to do is: instead of using the resistive load bank, charge a bank of ultra-capacitors during high current braking instead. The on-board charger will then take the power from the capacitor bank and dump it back into the battery bank at a controlled rate.
I understand that most motors of this size use sensor feed-back, but was wondering if any have been developed for sensorless feed-back?
Any help would be appreciated, Bill
