NickParker (Electrical) said:
How do you manage when the mechanical equipments are not finalized early in the project as it happens in every other project. There would be frequent changes in the electrical power requirement of the loads until the mechanical capacity of the loads are finalized.
Gunnar had a pretty good answer:
Skogsgurra said:
I try and get top management involved as soon as possible and make them understand that there's a choice - either a large margin and the costs associated with it or the rework and late delivery of key components and the costs associated with that.
What you are discussing is really a scheduling issue. I, however, was never any good at the "make them
(top management) understand" part. The top management concern is always about the money. And it should be. If the project doesn't make money, no one will sign paychecks. However, as long as the management bonus' is based on short term income, projects will be based on least capital investment. Issues such as creditable project timelines, life cycle costs, ease of maintenance, even reliability, are in second place. I have not seen a change in that philosophy in 50 years, I don't expect there will be a change.
Once I figured that out, about thirty years ago, I picked a career path where generally, that wasn't a problem. I'm an industrial grade field dog - those of us that take those beautiful drawings, that were designed such that the equipment fit on paper really well, and build something that is safe, reliable, and fits the customers requirements. I am one of the few people that have managed to claw their way down from management back to engineer.
My involvement with the level of meetings you and Gunnar are discussing is generally limited to technical expert. Conversations like:
"Yes, we can do that. It will require we violate a law of physics, which we can do, but it costs a lot of money. However, the next issue I see here requires a second physics law violation. We can usually do one, but generally not two."
My approach: Run away from design house jobs. There's no money in it - unless you choose to not have a life.** So, don't worry about it.
In the mean time: The mechanicals control the job. Production doesn't care how the pump gets turned, they just want the RPM right and the Torque available. When you get the final load data, you will provide the final power design. And when there are significant design changes, you will put in for the cost overruns.
Life Happens
carl
Harmless flakes working together can unleash an avalanche of destruction
