Hello all,
First I hope this it the right forum - please advise me if I need to post at another forum.
I am a fair Mechanical Engineer with a specialty in pressure technology (piping and pressure vessels). My familiarity with things electrical is limited to my 66 years of experiences with electrical shocks.
My only remaining vice is radio. I like to participate in short wave listening. This hobby covers utility broadcasts, police, fire, amateurs, aircraft, and most frequencies between 150 khz and 2000 mhz. Many of my receivers and transceivers are powered by 13.8 volts DC. The required amperage for the receivers is less than 7 amps but some of the transceivers require 30 amps.
I have been given 10 (originally quite pricey) rack mount regulated power supplies that I would like to try to use. They are all Electronic Measurements Incorporated models with variable voltages (e.g., model TRC 20S30 allows voltage to be set between 0 volts and 20 volts at 30 amps).
So I had a 220 line (10 gage wire) installed to my radio room for one of the power supplies. So far all is well, that EMI 20S30 supply is a "single phase" supply. But then I "discovered" (duhhh) that some of the bigger (100 lbs!!) TRC 7.5S300 (yes, 300 amps!) power supplies (two 7.5 volt supplies in parallel will give me 15 volt capability) are three phase and I do not have three phase into the house.
All of that boils down to my question - can I somehow "convert" three phase power supplies to use my single phase 220 circuit?
Keep in mind that I am a Mechanical Engineer with shock induced curley hair (and not much of that left). There is not much of a market around home for boat anchors.
Regards, John.
Regards, John.
