electrically conduvtive adhesive, not epoxy
amir11950
1
Hello everyone. I was trying to find some electrically conductive adhesive. I know that automatically means epoxy but I want the kind of adhesive that you find on the back of stickers or labels. Basically a re-appliable adhesive which i think is called pressure sensitive adhesive.
Any ideas?
There are several electrically conductive adhesives with aluminum, copper, and gold carriers that are available by several different companies.
Things to consider is galvanic interaction between the conductive carriers to avoid rust and corrosion issues. You also need to know the amount of resistance you can tolerate and the adhesive strength required.
