Thanks;
IRStuff:
Only requirements I can think of at this stage (and with my knowledge) are, max temperature; 180F, thickness; upto 1/2 inches. Values about electrical or thermal insulation? I dont feel like I have that info or the luxury to ask those at this moment. I mean, if I find something with 50 WmK, it is better than nothing. Or 40 WmK but cheaper, it will work better.. I just have to see the cost.. Then if affordable for the product, think of it as $s per W/mK, then test it on its place to see what difference it makes..
I am checking the alumina pads, I think 1550C temp is kind of overkill for my 180F application, and for 0.13 thermal conductivity, it may just not worth it, I am cheking...
Itdepends:
Thanks but thermal grease wont stay there for long , I need something that can hold itself better, for example, a soft blanket would stand there.. (I forgot to say that the application stands vertical, Itdepends, sorry, my bad).
Gruntguru:
That WORKS, (if it is affordable), I am on it! I am giving you a star for the best answer, thank you very much
Guys, I appriciate your attention))
