Hi guys, I'm new to this forum and I have what I think is a basic question. I'm not much of an electrical engineer, so I hope it does not sound too silly. I have the basic equations that characterize the magnetic field on axis with a solenoid shell at a distance away from the solenoid. However since the field falls away so quickly I wanted to concentrate the flux with a solenoid with some sort of core (probably ferrite). I only need a magnetic field a few millimeters away from the electromagnet, but it will not make contact with the magnetic substrate. I have tried to find equations to help characterize the field away from a solenoid with a core but have not been able to. I also looked for commercial electromagnets that may have specific field equations for that particular electromagnet, but none I found have the formula, plus they are all contact electromagnets.
Any ideas on where I can get (or I guess make?) an electromagnet to attract a magnetic material from a distance of a few mm and its magnetic field equation so I can model it?
I'm currently working on specifics, as to how much of a field will be necessary to create the force I need.
Thanks already,
George
Thanks already,
George
