I have seen that you can get electronic transformers for halogen lighting these days.
However, nobody wants to say much about what comes out of those.
It seems the device is switching internally at 20 kHz or so,
but do you connect the bulb directly to the secondary output of
the switch transfornmer ?
I would not use that in a sensitive environment. The EMC fields must be huge !
Or is the output somewhat rectified / filtered like a SMPS ?
