Guest
if electric current is the flow of electrons, and electrons are already present in a conductor and not generated by a source such as a generator or battery. then how is it possible for an atom to contiuously loose electrons? will a conductor eventually loose all electrons? if not how are they continuously there to "flow"? if all current eventually goes to ground then what? my mind is about to explode, please explain.
thank you
thank you
