I've been tasked with performing research on the issue of levels of ESD build up and discharge from railcar tankers before the process of petroleum transfer. Specifically, looking into a specification that our products can be tested to that would cover the connection of an electronic device to a railcar that has not been properly bonded and/or grounded.
API2003 covers a recommended practice for bonding and grounding of a railcar tanker before product transfer, but as can be expected these practices are not universally followed. Although API 2003 discusses charge accumulation _during_ product transfer, it does not discuss charge accumulation as a result of railcar movement.
What I'm looking for is some sort of research that would support waveform and magnitude criteria in order to conduct a reasonable test that would simulate - on some level - the worst-case electrostatic discharge of a railcar. So far all I've managed to come up with is a vague reference to a British study that suggested a typical stored charge on a tanker truck with 30KV of potential is 2250 millijoules. Since road vehicles typically have inherently dissipative paths, and rail vehicles usually have non-conductive bearings and wear pads isolating the tank from the rails, as well as a significantly larger volume of 'dielectric', it’s safe to assume that the stored energies on a rail car will be much larger.
I'm looking into DO-160 EMP waveform 2 stimulus - This seems to be the closest thing I can dig up that might approximate a large ESD event occurring upon the connection to a railcar with significant static accumulation.
Any suggestions of regulatory agency recommendations would be helpful.
James
James
