CKJK
Chemical
- Jul 26, 2020
- 24
Hello all,
I found a problem in my simulation, there is a warning that the element type is not available for the simulation. I consider it is the problem causes my rebound process not to act as the material values I give. The property I gave to my model is water property, in realistic, liquid will not bounce at all. I am not sure if it is only element type causes unrealistic result, or I need to define more thing for the visualization I expect?
I attached the cae file here. Hope someone can take a look and help~
Thanks a lot in advance!
