Elevated steam trap 1
sshep
Chemical
Feb 3, 2003
761
My friends,
We would like to run a 350 psig steam line under a road which is basically level grade. It could be fully encased or in a bored sleeve with pits at each end, that is not yet decided.
I would like to have traps which are at grade. This means a line or syphon from the boot running up to the trap. What is the best trap type(s) and installation considerations.
Best wishes,
Sshep
With the traps at grade it´s no possible to drain the boot. It´s better to put the trap under the boot in a pit and discharge the condensate of the trap to the atmosphere.
casflo
Hey Alfredo,
Thanks for reactivating this thread with an answer.
I am guessing TD=Thermodynamic. This sounds like a good trap to consider. I know it has to be theoretically possible to have an elevated trap since an orice trap and syphon would do it. I beleive the basic requirement is something that won't vapor lock, however the little research I did yielded very little discussion on the pitfalls of having an elevated line drain trap.
Any further advice or comment is welcome. My problem is still active.
best wishes,
Sean
