Elevated Temperature Tensile Data for Steel 7
materials2018
Materials
Sep 4, 2018
4
Hello, I have been searching for high temperature tensile data for many grades of steel and weld filler metal such as ASTM A656, A514, A36, A572, ER70S-3, ER80S-D2, LA-90, and 307Si. I have searched the following databases with no success:
• UW-Madison - Research Papers Online Library
• Our library and reference books
• DTIC Online
• ASM Alloys Online Database
• ASM General Papers Database
• HIS
• Steel Tube Institute
Is there any online resource that would have the data I am looking for? Our only other next step is conducting the testing ourselves. Thanks.
Why? Is this some type of research or are you building a new database?
Start with the ASME Boiler & Pressure Vessel Code Section II Part D - this gives both design and typical properties for materials meeting Code.
ASM publishes a book of high temperature properties of ferrous alloys.
When I get home I can get you the exact reference.
I had an internship at a DOE site where they had me put these tables together of properties of structural steel, stainless steel, and aluminum alloys at elevated temperatures. I have attached it, feel free to use it, just don't go publishing it as your own. I think I cited where I got the numbers from. The ASME Boiler and Pressure Vessel code is helpful, AISC has a design guide with some good information, (Facts for Steel Buildings: Fire). The AISC 360-10 code has properties of steel at elevated temperatures in Appendix 4.
 https://files.engineering.com/getfile.aspx?folder=cd295347-e2da-4b03-87d1-331ed9c82e30&file=Properties_of_Steel,_Stainless_Steel,_and_Aluminum_at_Elevated_Temperatures.pdf
High-Temperature Property Data: Ferrous Alloys, ed Rothman, by ASM
ISBN:0-87170-243-6
Depending on the alloy it lists mechanical and physical properties over a range of temperatures.
The FAA publishes an enormous volume of materials data, which includes high-temperature properties (not just tensile strength, but modulus, thermal conductivity, etc.)
The current publication "AR-MMPDS-12" requires a purchase, but previous versions, which were actually published by the US Military, were not.
That document was known as "Military Handbook 5" or "Mil-Hdbk-5" and it's still out there for free download. Warning: (70 Megabytes).
No one believes the theory except the one who developed it. Everyone believes the experiment except the one who ran it.
STF
Be careful when using any of these guidelines for LONG TERM, HIGH-TEMPERATURE APPLICATIONS FOR CARBON STEEL..
The information about the behavior of structural steels ( A7, A36, A53 etc)is based on short term fire properties.
ASME B31.1/B31.3 and many other publications warn against the design and usage of carbon steels when the operating temperatures are 825-1300F.
Carbon steel degrades and loses structure via a process known as graphitization.
There are also maximum limitations to stainless steels
There seems to be no long-term temperature limitations in these guidelines .....
MJCronin
Sr. Process Engineer
