Magnetic Materials for moderately high temperature use 2
Scott Price
Nuclear
Sep 18, 2024
I need to survey a list of materials capable of high (permanent) magnetization that will withstand modestly high temperature preparation for use (vacuum bake-out at roughly 120 C to 200 C, let's say, for a few hours).
Density of likely candidates I've seen so far run to 7.5 - 8 g/cc. This is fine.
For the moment, I can only use commercially available materials, fashioned into small ~ 6 - 12 mm diameter, 6 mm thick (cylindrical).
Neodymium compounds/alloys are appealing.
Any others?
Another option would be Samarium Cobalt, which can easily accommodate that temperature range. The density is 8.4 g/cc, a little higher than NdFeB.
If you can find a 2:17 SmCo magnet you would better off.
NdFe magnets don't really stand a chance.
Repeated cycles to 150C will cause noticeable degradation in magnetic properties.
MagMike, EdStainless,
Both: thanks so much. The advice is running to Samarium Cobalt, at 8.4 g/cc, yes it's a little heavier per unit, but survival is key.
Best,
Scott
