WHAT IS GOING ON:
The steam coming out of the boiler contains CO2 which disolves in the condenser and forms carbonic acid, which causes corrosion in the condensate systems. The chemical that is being injected to control that corrosion is Tri-act.
WHAT DO I WANT TO DO:
I want to install a degeaser unit or flash drum right after the boiler unit, that will take away the CO2 from the steam and that way we wont need to inject Tri-act anymore.
If I install a flash drum, we'll have to play around with presure and temperatures, to transform steam into water and keep CO2 as gas to venet it out.
WHAT DO YOU GUYS THINK? ANY IDEA?
