PaulKraemer
- Jan 13, 2012
- 152
I am trying to design an Industrial Control Panel that will replace an older Control Panel that is currently being used in a machine control application. I have posted a several questions related to this project, and the responses I have received have been incredibly helpful. If everyone here hasn't grown too tired of me by now, I have one more...
While the new components I'll be using in the new panel in most cases are a bit smaller than the old components in the old panel, I have found that the old panel has virtually no branch fusing. The only over-current protection for many of the components inside the panel is from the main circuit breaker that supplies the entire panel. In the new panel, I am planning to include branch fuses for each individual component. This has resulted in my current (preliminary) panel layout being more cramped than I would like it to be.
One opportunity I thought of that would free up some space would be if I could eliminate a transformer in the old panel that takes the 208 VAC supply voltage down to 115 VAC for a few components that require the lower voltage. I will have components in the new panel that will require 115 VAC, but I am wondering if the facility can provide me with a four wire 208 VAC supply circuit (3 phase plus neutral), if I can get the 115 VAC I need between one of the phase lines and the neutral.
Before I consider doing this (and asking our electrical contractor if he can give me the neutral, which is not in use on the old panel), I figured I'd ask here if there are any drawbacks I should consider if I think about going this route.
Any advice will be greatly appreciated.
Thanks in advance,
Paul
Thanks in advance,
Paul
