Ellipsiodal Head: external Pressure
Water_Guy
Industrial
Sep 6, 2016
10
Section UG33 (a) (1) provides to use Section UG32 (d), along with UG33 (d) for external pressure on ellipsoidal heads.
Section UG32 (d) formula (1) is applicable for 2:1 elliptical heads (manufacture's standard). What if the head is fabricated for a large vessel, where say the inside diameter is 77' and 1 minor axis is 31', a 2.48:1 ratio and the other head minor axis is 26', a 2.96:1 ratio ? I don't see where the Code provides for such a scenario.
On UG-33(d) take a look into Table UG-33.1, this table is in terms of outside dimensions, skirt outside diameter Do, outside axis ho, then you get factor ko and then Ro = ko*Do. This table covers a range from 1.0 to 3.0 but since you mention inside dimensions you must check if outside dimensions fall within this range.
You shall follow steps 1 to 6 of UG-33(d) to get the external pressure for each head. Don’t’ forget to check against UG-33(a)(1)(a).
Hope this helps.
