cmb042
Geotechnical
- Apr 28, 2008
- 39
Main Question: Is the elongation value of any objective use if the part is designed to operate below yield strength?
I understand that in sheet metal bending or interference fits knowing how much strain a material can tolerate before breaking could be valuable. I have also had it explained to me that elongation is a subjective indication of material toughness, that higher elongation materials means higher fatigue strength. But if my part works in an environment where plastic yield is considered a failure, so the part is designed to never reach yield point (in theory), then should I care what the elongation of the material is?
I have a recent shipment of 303 barstock with certs that match ASTM A582 requirements. UT and YS are near typical values per the ASTM handbook. However the elongation on the cert is half that of the typical value. What is the risk of using this material if the parts made from it are designed to operate below yield strength? Why would this value be so much different than published values?
Thanks.
Thanks.
