Alvarobg
- Oct 8, 2015
- 22
Hello every body!
I am designing an steel anchorage and I have one doubt. I have a bolt postensioned, which has not contact with concrete. It is joinned with a steel plate which is embedded in concrete. When calculating the steel plate: Can I consider that the embedment improve the strength of the plate? or I have to consider uniquely the plate thickness?
PD.: attached sketch.
Thank you
Thank you
