Can someone please tell me the effects of the following scenario? A 36 inch steel pipe approximately 1 km long, used as an emergency flare line- containing a mixture of gas vapour and steam. Line temperature of 95 degrees centigrade. If a quantity of cold liquid butane was to be injected into the line- say 5 to 10 cubic meters- what would be the result? Would the butane boil off causing a pressure increase or would it cause a vacuum- possibly collapsing the pipework?
