farmer2
- Jul 29, 2006
- 57
I am looking for a push-button operated emergency shutdown switch for use at up to 400 amps, 12V DC and up to 200 amps, 24V DC for winches per an EN standard. These are full-load amps for the winches. At stall torque the motor may draw 50% higher current which I assume should be the max. switch rating (600 amps 12v, 300 amps 24v).
The IEC spec is called out in the EN winch standard and also says "switch shall be of the self-latching type and shall have positive (direct) opening action. Actuator shall be of the palm or mushroom head type, colored red, with the background around the actuator colored yellow"
Are the above requirements specified in the IEC spec and does anyone know any manufacturerers of such a switch? I do not have a copy of the spec.
Thanks,
Thanks,
