EN 13445-5: Equation 5.4.2 - The number of equivalent full pressure cycles
SD12
12
Hello!
I have made a calculation of the number of equivalent full pressure cycles and my result is far more than 500 cycles.
What is the procedure then? Should I take the number of equivalent full pressure cycles and compare it to FAT 100 S-N curve? Or it is more complicated than that?
Do we have worked examples on chapters 17 and 18 of EN13445-3?
That's defined in EN 13445-3, para 5.4.2, a.o. the last sentence.
Code:
If these conditions cannot be met, then a fatigue assessment is necessary according to either Clause 17 or Clause 18
Does this answer your question?
Huub
- You never get what you expect, you only get what you inspect.
I actually haven't seen this sentence. I have the standard issue from 2015.
Thank you.
Are there any worked examples for chapters 17 and 18?
2021 is current
Havent looked, but get a copy of the standard, and get to know your standards.
Huub
