gatossi
Materials
- Feb 20, 2007
- 24
Type A fittings are defined as "having the same thickness in the body as in the welded end" and in most cases have a lower pressure containing ability than the pipe of the same thickness. So far I have not had any issue while selecting Elbows, Reducers and Tees (EN10253-2 clearly shows the Pressure Factor for those)
When it comes to Caps, although they are shown in Table C.5 under the different series, there is a note stating "For some dimensions no pressure factors are listed. In these cases, the dimensions of the cap are outside the range of validity of the calculation procedures given in Annex B; the usability had to be checked for each case"
Can anybody bring some light onto this statement?
If they don't comply with Annex B Calculations, why are they listed in the Standard?
How can the usability be checked? by testing (like a proof test)?
Any help is appreciated on this.
