jraef
- May 29, 2002
- 11,360
I am in need of a source for some 400A encapsulated bus rated for 500VDC. I need encapsulation because it will be in a trough that will get water in it during rain storms. The water will drain away but will likely fill the trough under worst case scenarios. Connections can be made in a protected space at levels above the maximum water fill, but the bus itself must be in the trough, no way around it. I have seen several IEC sources but I need UL listing on top of these other onerous requirements.
Any ideas?
"If I had eight hours to chop down a tree, I'd spend six sharpening my axe." -- Abraham Lincoln
For the best use of Eng-Tips, please click here -> faq731-376
Any ideas?
