Scott Chapel
We built our first production skid and are working to reduce the heat load in the electronics compartment. Referring to the attached CAD drawing, the bottom right of the skid is the compartment. Currently the external walls/panels are 20-gauge steel sheet powder coated yellow. There is 1-inch of R-6 foam board insulation on the inside of all six external walls. The two outside facing panels are exposed to both ambient heat as well as direct sunlight when the skid is unloaded on site. What I have been unable to figure out is, if we were to replace the 20-gauge sheet steel with aluminum sheet, would this reduce the heat transfer into the compartment or is the powder coating and color the deciding factors in the heat transfer.
Appreciate any help!
Scott
Scott
