SA07
- Feb 22, 2018
- 365
Hi We have a VSD 800 kW on a boiler fan 700 kW motor speed 742 rpm voltage 690 Vac. Sometimes when there is a network disturbance, the VSD tripped. We have program reset fault and restart for 3 times. We have put a delay in the PLC program to give the VSD enough time to restart. Most of the time the restart after a fault works. Will the installation of an encoder on the motor shaft improve the VSD restart after a fault? If after some time of operation, the encoder fails during normal operation, any idea how the VSD will react? Will it trip? VSD is Siemens Sinamics S150
