End Of Month 1
Codemage
Computer
Jun 2, 2003
6
i need Some Code to Find if its the End of the Month
and what month we are Currently on. useing the calendar Control in VB
The end of the month can be done with something like:
If Month(myDate+1) > Month(myDate) Then
' myDate is end of month
The name of the month can be got from :
Format(myDate,"mmmm")
Using "mmmm" above will give June
Using "mmm" above will give Jun
Using "mm" above will give 06
Using "m" above will give 6
Good Luck
johnwm
Were is MyDate Coming from ?
the example you provided does nothing
I assume myDate is your date variable. If you are using the current system date, just use the Now function.
DimensionalSolutions@Core.com
While I welcome e-mail messages, please post all thread activity in these forums for the benefit of all members.
Public Function MonthEnd() As Boolean
Dim myDate As Date
myDate = Date
myDate = myDate + 11
If Month(myDate + 1) > Month(myDate) Then
MsgBox myDate & " is the end of the month."
MonthEnd = True
Else
MonthEnd = False
End If
End Function
This should od it for you.
Derrick
