TTTKAO
Mining
- Aug 24, 2022
- 79
Hello Everyone,
I am designing a stabilizer which will provide lateral support only for a structure.
the stabilizer is a W shape beam and connects to column flange directly. I plan to use an end-plat connection between
beam and column. and set vertical short slot at column flange and horizontal short slot at end plate to release shear load at this connection.
May I ask is there any concern for this connection to transfer axial load, I am wondering if the slot can transfer axial load properly?
Thank you for your advice and suggestion in advance.
