chekre
- May 8, 2013
- 173
Hi guys,
i am having some problems with a concrete slab spanning one way 14 meters and supported on 1200x350mm concrete columns( the 350mm is perpendicular to the span) . The reinf't in these columns is coming too much due to the portal frame action(the moments are coming mainly from gravity loads (unbalanced moment)). I have run the model assigning 0.7 for the major direction and 0.5 for the minor but still, ratio is exceeding 4%. I was thinking of assigning end releases at the bottom and top of these columns and the slab will be designed as it was resting on pinned supports
Is this acceptable noting that these columns are not participating not that much in resisting lateral loads and as mentioned earlier, the high moments are due to gravity ? and if it is not acceptable, what do u generally do in such cases?
