phoenix221
Computer
Hello everyone,
I have an interesting problem which I have been grappling with for a while. Thermodynamics is not my specialty, so this problem proves exceedingly difficult. I need a sanity check on my computations and even some help if it proves that I am out to lunch
The Problem:
I have a small surface exposed to 120mph wind, high moisture in an ambient temperature no lower than -4F. Ice forms of varrying thickness on this exposed surface, this ice needs to be removed in cycles. Each ice melt cycle will unfortunately be very short between 3-5 seconds. The idea I am considering is to use a kapton flexible heater if possible. To determine the viability of this idea, I need to determine the watts/square inch required to be outputted by the heater.
Assumptions:
1. There is no need to melt the whole ice. It is sufficient to liquify a thin layer, say 1/16th, the ice then gets literally blown off, i.e. mechnically removed, by the wind, or slides of due to its own weight!
2. Energy requirements need to be calculated for
a) the heat needed to warm the ice to 32F
b) the heat needed to melt the ice, i.e. heat fusion
c) the heat needed to warm the water to 33F
3. Need to determine the wind-chill equivalent temperature
The Reasoning (faulty as it may be
1. Wind-chill equivalent temperature according to the new windchill index: -47.33F
2. The temperature change is Dt=-47.33-32=-79.33 (I'll ommit the (-) sign for calculations).
3. The weight of the ice being warmed is determined by using an average density of ice of 57.67 pounds/qubic foot. The weight of 1 qubic inch of ice is 57.67/1730=0.0333 pounds. Now as per my assumption I am really melting 1/16th of an inch of the total ice only so my weight for computational purposes is M = 0.0333/16 = 0.00208 pounds
4. I will use the following formula to determine the watts required for warming the ice to 32F:
watts=(M x Csp x Dt)/(3.42btu/watt hr x Th)
where
M - weight of material (lb)
Csp - specific heat of ice (Btu/lb F) = 0.5
Dt - temperature rise (F)
Th - heatup time (h)
Watts = (0.00208 x 0.5 x 79.33) / (3.42 x 1) = 0.02412 watts
5. I will use the following formula to determine the watts required for converting the ice to water at 32F without a change in temperature:
watts=(M x Csp)/(3.42btu/watt hr)
where
Csp - specific heat for heat fusion (Btu/lb F) = 144
Watts = (0.00208 x 144) / (3.42) = 0.08757 watts
6. I will use the same formula as in step 4. to determine the watts required for warming the ice to 33F except we'll work with Csp=1 and Dt=1 so...
Watts = (0.00208 x 1 x 1) / (3.42 x 1) = 0.00081 watts
7. the total:
So this gives me a total of 0.02412 + 0.08757 + 0.00081 = 0.112508 watts/hour/square inch.
For a 5 second performance I will compute (0.112508*3600)/5 = 81.005 watts/square inch
For a 3 second performance I will compute (0.112508*3600)/3 = 135.009 watts/square inch
However I have the feeling that something is wrong with this approach! In addition to whatever errors I may have comitted, I suspect one also would have to account for the wattage for heat loss between the layer being flash melted and the rest of the ice... and perhaps there are some other things I am missing as well...
I am also seeking advice on what a reasonable padding of these numbers would be to account for unforseen issues...
Any help would be appreciated...
Thank you in advance
The Problem:
Assumptions:
where
where
7. the total:
